Felt-pro Printoseal intake gaskets part #
    What is the correct part number for a 1989? Do you have to use gasket sealant with these?
    MS93334 is the intake set. This has both head to intake gaskets, the two end pieces, plus the upper to lower intake gasket. Some people use RTV at the water jackets, and you'll need a blob at each corner where it meets the rubber part that sticks to the block at the front and back. I don't use any RTV on the water jackets myself.
      Personally I don't use the end gaskets. I run a bead of RTV instead of using the end gaskets. And I don't use sealer on the intake gaskets but I do use some gasket adhesive to hold them in place on the heads.
        well I just ordered some from JEGS, I'm going to start work on it on Friday. I need to get her running again!!
          I just buy them local. The set cost me $20.88 and the mom-and-pop had them on the shelf. I forgot to mention it also comes with an IAC gasket and a distributor O ring.
            I use a big bead of RTV on the ends, and a thin bead around the water jackets.
