Could it be the exhaust valve thingie? I'm thinking when it heats up that it could be flapping and making a banging sound? But even then I dont think it could make that loud of a noise.
Sounds like a chicken under my hood!
dude, like i said, sounds like you have the same prob i had, it was a sticky lifter so i put in a can of winns engine tune, witch frees suck components, and its been good ever since.
I 2nd the flexplate. My 76 Chevy pickup has a cracked flexplate. It sounds like a lifter going but it isn't. Check it in different gears. it is louder in drive then it is in park, but the noise on my truck is constaint and just louder depending on which gear it is in.2000 Mustang GT "Blondie", 2000 CVPI "Sargent Crusty"
My k5 had a bent flywheel. Anything is possible. Id check the flexflate or flywheel whatever you call it.1989 Grand Marquis LS
Well, it turned out to be the starter. The starter gear kept flopping back and hitting the flywheel. I went down and got another starter and the noise is gone! While I was down there I found my front oil pan bolts were loose which might be why I have quite the oil leak on the front of the motor. So hopefully those are what was causing my oil leak.
me too
Probably the bendix drive wasn't fully retracting and clattering on the ring gear.86 Lincoln Town Car (Galactica).
The bendix was so loose. if you shook the starter the bendix would just go in and out.
