02 Sensors
    02 Sensors
    I'm changing my 16 year old extended o2 sensors. The computer has been reset a couple of times. Getting the new ones today. When I install them are they going to read right, or do I need to reset the computer again?
    1989 LTD Crown Victoria LX.
    -3.73s' w/ Track Loc - KYB GR-2 Shocks All Around - TRW HD Cargo Coils Rear - Moog Front Coils - 1 Inch Rear Sway Bar - 4.6 Lower Air Box- Stock Headers - Off Road H Pipe - Turbo Mufflers.
    4 Door Muscle
    Supermotors
    Can't hurt to reset the ECM
      I'll just unplug the battery when I got to put evertyhing on.
      4 Door Muscle
      Supermotors
        How much did they cost you?
        1989 Grand Marquis LS
          75 for both.
          4 Door Muscle
          Supermotors
            That's what's nice about CFI, there's only one lol.
            '95 Ford Bronco XL -
            sigpic :rebel:
              How hard are those to replace, seems like getting to them and then breaking them loose will be a bitch and a half... Also for a TC which one shall I get, with the short or with the long harness?
                They come out of the manifolds like cake with PB blaster. IT was harder getting them out of the H pipe on one of them. The hardest part is getting them plugged into the harness on the right side (on the passenger side) so that the harness reaches the driver side.
                4 Door Muscle
                Supermotors
                  I think that's the only advantage to CFI. :evil:
                  Save a seal, club a liberal.
                    CFI sucks.
                    4bbl is bettah.
                      I prefer EFI myself.
                      I was thinking of a 351 for my vic. Do they make EFI ones. One I could find used and rebuild. Do they have an EFI swap for them?
                      4 Door Muscle
                      Supermotors
                        no efi 351 Vic ever existed. All VV carbs till 1991. The truck manifolds are different, but you can probably use a 351 Lightning upper/lower and make it work, but they aren't exactly the most common thing.
                          I'd hate to go carbbed. I love EFI. 302 it remains.
                          M/mm I really want to build a Stroker Big Block track vic one day.
                          4 Door Muscle
                          Supermotors
                            How about a truck 351 with a Mustang EFI upper on it?
                            Nick
                            88 Colony Park LS
                              The 351 ports on the lower are bigger and a different shape than the mustang upper. On top of that a mustang upper does not flow enough to support a 351W Best bet would be getting the Edelbrock 351w efi intake.
