hey what gives!
    hey what gives!
    before my HO conversion the car would chirp when I would floor it from a stop. Now after my HO conversion which was supposed to ADD torque, it won't chirp. Whats going on? Is the mustang cam that upper end? What are your guys experiences. Maybe I need 3.55 or 3.73?
    If your car chirped before it was a freak of nature.
      :stupid:
        Mine would spin a tiny bit with the CFI. But now I have bogging problems from a stop with the carb and cam. ::
          Do you have a HO governor in the trans? If not you are shifting way to early, way before the torque/HP peak. Shift it manually and it might.
            He is saying that from a dead stop if he puched it it would chirp. This is not something a factory panther car can normaly do.
              I got the govenor, but I'm talking about from a stop. If I didnt have my high rpm power loss I could really chirp em on the 1-2 shift tho.
                My grandparents 86 gm can spin em a bit.
                  If I punch mine it goes squeals. Not chirp squeals. Mine is stock except the ecu
                  1989 Grand Marquis LS
                    I was able to chirp mine at the drop of a hat when I first got it...
                      yup my 89 lopo with single exhaust would chirp it if the AC was off and no one was in the car but me, from a dead stop. the chirp would only last about 1 second though.
                        Probably the slight loss of low-end torque from the opened up exhaust...
                          :stupid: , actually. I thought to mention that, but got a phone call.
                            My tired 167,000 mile 1989 Crown Vic would spin its one tire and my 1989 72,000 mile Grand Marquis will spin both tires from a stop - for about a second. I think that's normal - depending on the quality of your tires, I suppose . . . .
                            Remember, when the convertor stator isn't turning, the torque multiplication is at its highest. If what TCI information says is accurate, the torque multiplication for a stock converter can be about 2.5! So, with our stock engines, with torque maxing out at a low 2000 to 2400 RPM, we can send over 500 ft-lb or torque to the rear wheels - that is, until the stator starts turning - that's why we can "chirp" them tires - if only for a second.
                            HO with Explorer Cam, Electric Fan, Cop Sway Bars, Dual exhaust with no mufflers, 15x7" American Racing; 215/70R15's front, 255/60R15's rear, 3.55's with Trak-Lok.
                              HUH? Every one of mine could...even the 2.73 geared 91 Marq...in my vids, the one with both panthers running. The tire spinning you hear is the 91..not the 87...
                              The main reason isn't the opened up exhaust, it's the HO. The torque peak is higher than a lopo.
