hey what gives!
    But to answer your question . . . .
    I suspect that the main reason that you can't chirp from a stop is that the torque curve of your motor has "shifted" up 1000 RPM from 2000 RPM stock (at 270 ft-lb (stock Lo-Po rating)) to 3000 RPM (300 ft-lb (stock Mustang rating)). Although the Mustang torque curve doesn't ramp down too quickly (vs. RPM), I suspect that your off-idle torque is lower with the HO setup.
    HO with Explorer Cam, Electric Fan, Cop Sway Bars, Dual exhaust with no mufflers, 15x7" American Racing; 215/70R15's front, 255/60R15's rear, 3.55's with Trak-Lok.
      Yeah, off idle power is less with an HO. They really don't have a whole lot of grunt under about 2000 rpm, and with the exhaust being open, it has even less.
        I boil both tires if i punch it from a stop.
          DuceAnAHalf - with your motor (NOT a 5.0 HO conversion for you readers - at least that what www.supermotors.org says), I'm not suprised!
            More to come.
            When the original CFI lopo blew it was replaced with another lopo but had a Weiand Action plus intake and a holley 600 vac secondary carb. the car had suprisingly good pickup through 1st gear. not sure if it would spin the tires, but would jump out there rather quick.
              89LincolnTWNcar - check your Private Messages!
                Duce, my car is the same way with the edelcrock carb...
                I know a good set of heads and a cam would really wake that car up...
