can i wire a 5.0 tps sensor plug to a explorer 5.0 tps? same question with using the explorer iac and wiring the proper plug to the harness?
see i am installing a new explorer crate engine......trying to save the customer some money as these sensors are brand new.........the injectors will work,mrltd is using his set he got with his 96 explorer crate motor mine the part number of the injector is F4SE-A1B
scott
scott
