Belts
    Belts
    What are a good set of betls to get for my motor?
    They started squeekin like 5 years ago. Replaced them. I'm getting a squeek when I start the car now.
    1989 LTD Crown Victoria LX.
    -3.73s' w/ Track Loc - KYB GR-2 Shocks All Around - TRW HD Cargo Coils Rear - Moog Front Coils - 1 Inch Rear Sway Bar - 4.6 Lower Air Box- Stock Headers - Off Road H Pipe - Turbo Mufflers.
    4 Door Muscle
    Supermotors
    I use those cheap drive-right belts and they work fine. My 98 integra squeals at startup as well, its normal.
      I'm replacingi them because last time they started to squeel at start up they started to squeel non stop.
      4 Door Muscle
      Supermotors
        I use Goodyear Gatorback, never heard a squeel, and I do drive in rain, cold, and snowstorms.
          I have gatorbacks on both cars. the 97 squeels on start-up only due to dew on the belt and pullies. The 85 will squeek a little right after start-up if i have the fan on.
            Ive used gatorbacks the last couple belts i got and they worked great. definitly didnt hear no squellin after i put em in, there pretty good quality.
            I am the GOD of ELeCTRIC HeLL FIrE!!, and I BrinG YOu..........
              El Cheapo's. Never heard a squeal unless I was playing in the mud.
              1989 Grand Marquis LS
                as long as there new they shouldnt squeek, my belt of choice is gates
                1999 CVPI
                Old Rides
                1988 Ford Mustang GT (trickflow stage 1)
                1989 Mercury Grand Marquis LS (5.SLO)
                1989 Ford Thunderbird SC (3.8 Supacharged)
                  ...and add mud. :evil:
                    My dad actually just brought me home a set of those.
                    4 Door Muscle
                    Supermotors
                      I know I'll never buy a Dayco again...
                      '95 Ford Bronco XL -
                      sigpic :rebel:
                        Yeah, Dayco belts are teh suck.
                        Save a seal, club a liberal.
                          Dayco belts are a waste of money.
                          I never liked belts from advance, even the dry-rot (drive rite) belts...
                          I like Gates belts from Carquest, or the Gatorbacks...
                            I like the heavy duty Gates "Fleet" belts.... I forget the exact model name.
                            But I've also used Goodyear with good results.
                            "Ad eundum quo nemo ante iit"
