I found out the timing was 20* BTC with SPOUT disconnected Now she runs a lot smoother and stronger
Check for timing advance. Make sure its 10 degress BTDC with the SPOUT unplugged. As soon as you plug it in at idle it'll jump 10 degrees or more. Without that connected you'll have zero advance which will seriously affect power and might cause that popping. Its pretty common for people to set the timing to either 10 ATDC or set it with the SPOUT plugged in, which really screws the whole thing up.
OH NOW I REMEMBER, at the shop we did it with the SPOUT connected!! I will fix that tommorrow with my timing light.
1989 LTD Crown Victoria LX.
-3.73s' w/ Track Loc - KYB GR-2 Shocks All Around - TRW HD Cargo Coils Rear - Moog Front Coils - 1 Inch Rear Sway Bar - 4.6 Lower Air Box- Stock Headers - Off Road H Pipe - Turbo Mufflers.
No. Timing being off is a mechanical problem, not an electrical problem. Say you have a burnt valve, that's not going to trip the CEL. If you have a bunk TPS, that will trip a CEL.
