Lifter question
    Lifter question
    Okay, so hopefully sometime next week or the next after that, I will be getting GL back (cross your fingers mangs) and soon after that (when I get another job, again, cross your fingers) I want to start pulling the engine and doing the 4BBL/head/cam swap. Heres the question: can I use stock lifters with my cam? It's a Comp Cams 4X4 truck cam (.477/493 lift, 210/218 dur). I can't seem to find the right lifters in the summit catalog, is it alright to get new stock lifters and use those, or do I have to get aftermarket?
    Thanks mangs
    I know of guys with turbos running stock-type lifters.
      Get this set up
      This Cam
      and These lifters Then spin it to 7500RPM.
        get new lifters.......not a good idea to reuse flat tappet lifters
          Flat tappet lifters are burned in at the first engine fire up and sort of form themselves to the cam lobes. If you get a new cam, you need to get new lifters. Speed Pro HT-9000 is the part # i believe. about $45-50 for a full set. The local parts chains shoudl have them, its a common Ford flat tappet lifter.
          '80 Town Coupé
            I thought he was saying he's replacing them either way and was curious whether he can use stock type or aftermarket.
            Definitely replace, but stock type should do fine.
              Yep, cant reuse lifters. Lunati vodoo :evil:
                I didn't say anything about reusing the old ones lol
                Thanks for the info guys!
                  A roller block would be much more gooder :drug:
                    ROLLER BLOCK!!!!!!!??????, WHY YOUSE!!!!
                      Hey, I scored mine for free, you might be able to as well.
                        Chris has a good point. I wouldn't be too surprised if you can find a late model roller block that needs a crank kit or something for next to nothing. Then you can do your motor up on a stand and dump it in the car whenever its ready.
                          Well, I already got the cam, will it work on a roller block?
                            Nope. you will also need a distributor as the roller cams are hardened.
                              Im glad I kept the dist from the newer 302, Im just gonna swap gears.
