Are the town car balancer and the mustang balancer the same? (If not then wouldn't the timing markings on the towncar one with a mustang cam be off?)
harmonic balancer question
assuming it is the proper imbalance it should be the same. However if you got a 50 oz. imbalenve and you motor is a 28oz. then your motor will self destruct in a short while.http://secondhandracing.com/Home.aspx
#1 TDC is the same on any 302, so the balancer markings wouldn't be any different.86 Lincoln Town Car (Galactica).
