Originally posted by N A
Fuel pump questions
Where and how you mount them makes a big difference in the amount of noise they produce. Dynamat or some other sound deadener around the mounting area would make it alot quieter. Or even rubber washers on the bolts.Builder/Owner of Badass Panther Wagons
Originally posted by mrltdWhere and how you mount them makes a big difference in the amount of noise they produce. Dynamat or some other sound deadener around the mounting area would make it alot quieter. Or even rubber washers on the bolts.
Originally posted by Blaze86VicOriginally posted by mrltdWhere and how you mount them makes a big difference in the amount of noise they produce. Dynamat or some other sound deadener around the mounting area would make it alot quieter. Or even rubber washers on the bolts.
Thought that was kinda a given with the way the discussion was going...Builder/Owner of Badass Panther Wagons
