amp light
    amp light
    the amp light went off is it the alt or could it mean something else?
    the light usually comes on for two reasons: Over charging, or undercharging...
    Most likely its the alt... Also check all your wiring.
      Alts are very easy to pull out. I would take it out and have it tested. To narrow things down. If you have a voltage regualtor take it with you to get it tested too. Most autopart stores do it free.
        Mine would come on everytime I plowed through a lot of water. I just wiggled the cable and Off I went
        1989 Grand Marquis LS
          Alt or battery, could be wiring too like Tom said. What year is your car?
          '95 Ford Bronco XL -
          sigpic :rebel:
            89 the wiring didnt looik bad i know it is not charging i was able to drive it but the batt was only at <12 volts while running I drove it for a day and now the batt is too low to start. ill have tocheck the wireing tomarrow, what is the voltage reg. what symptoms would that cause if it were bad.
              89, unless its a police car, would probably have an internal regulator. If you have a silver box over on the driver's side fender then you have a voltage regulator. Most cars will not, and you'll have an alternator with two large plugs on it.
              If the VR were bad it would make the voltage high or low.
                Yes. If you have a 351, you'll have an external regulator. 302 was internal.
                  thanks for the help I think ill pull the alt later today and have it checked after school.
                    Police package 302s have an externally regulated alternator. I had a bad voltage regulator.
                    Save a seal, club a liberal.
                      it was the alt took me 20 min to get the old one out and the new one oin thanks for the help
