January is almost over and the track will be opening April 1st. I want to run an electric fan. What are you using and how do you like it?
Electric fans - What is everyone using?
The famoust MARK VIII does not fit??
I have seen a few show up in teh boneyard could score em for $20 or so
im using the 20" electric fan off of a 96+ Crown Vic. With the aluminum radiator keeps my Windsor cool, at least so far. if not i have a second one ill hook up as a pusher in front of the rad.
I have a 98 (or so) Vic e-fan that will eventually be installed. I just have to make some time and work out the installation details. Mine is the type that is the full fan shroud. Pulls a very large amount of power, like 20 amps low and more than 30 on high. Moves tons of air tho even on low.86 Lincoln Town Car (Galactica).
Some of the local guys are using the 3.8 taurus/continental fans. Used on a low setting, they have no problems at all with cooling. They should pull less than 40, so it will work with a stock charging system.
'80 Town Coupé
I doubt they still make Mark VIII fans brand new- the Mark VIII was discontinued in 1998. I'd go for a Mark VIII fan from a 97-98; those years were the most reliable and highest-flowing CFM fans of all the years. They were manufactured for Ford by Siemens, by the way...
:bump:Project \"Fire and Ice\":
1989 LTC
My worst enemies are those who presume me to be harmless. They cannot imagine how much I resent and disdain them, or just how great a threat they would face if I could get at them. Everything in their behavior speaks of insult and presumptuousness, and for now it is all I can do to make constructive use of my anger toward them. At this time, I just make a list of them and keep a watch on. Some day, with the help of time, space, and circumstance, I will be able to humiliate them properly - not in a manner they would enjoy, but in a style calculated to make them wish that they had never been born.
Anton Szandor LaVey
We've used the Flex-a-lite products for a number of applications.
One of the favorites around here for high performance street vehicles is the heavy duty 180. We have pretty extreme temperatures, and in the summer 100 degrees plus is common.
The 180 Magic X-Treme only pulls 18 amps, can be adjusted from 160 to 240 degrees, has a AC relay, and pulls 3,300 Cu. FT/Min.
They also have many stand alone controllers, and many single and double fan application specific options.
"Ad eundum quo nemo ante iit"
Originally posted by P71Times2http://www.flex-a-lite.com/auto/html/180_black_magic_x-treme.html
Can anyone find a price on that? I'm at work and today is one of the days the firewall is blocking Summit's site.2011 Mustang GT Premium, MT82, Kona/Saddle, HIDs, 3.73s, 19s, hood/side stripes, UPR 1.5" springs with adjustable panhard bar, and UMI solid LCAs and relocation brackets.
