Today i started taking apart my engine for the High Output conversion. If anyone has any tips or tricks that would help out a lot. Ill try to get some pics as i go along.
Starting HO conversion
dont forget to have the stock egr spacer bored out to 63mm
also make sure to get 8 injector service kits (o-rings, pintile caps and plastic spacers) i got them from napa for under 20 bucks........also i reccomend felpro permadry valve cover and intake gaskets
scott
:bump:Well i started along and got to the the last bolt on the egr spacer with i managed to round off, so now i have to go to napa and get the reverse sockets and get it stripped off, just one of the many bumps in the road i plan on getting myself into, for the throttle body, how to you disconnect it from the car, i have everything on it taken apart and its layin in the engine bay but i can slide the round part inside of it out to get the actual throttle body off. Thanks for the suggestions it will make this go a lot smoother, once i get the upper intake off im going to start taking pictures to post here.
hmm
are you working on it inside the car or did you pull the engine?
SuperFord Profile
Support safe sigs
-sigs should not exceed 600 pixels wide
-sigs should not consist of more that 25 lines (including pics) when viewed at 800x600
-Multiple images exceeding 600 pixels wide should have a space between them to allow for wrapping
-Total sig size should not exceed 60k
Remember, only you can prevent sig abuse....
Originally posted by Black_Night_SVT:bump:Well i started along and got to the the last bolt on the egr spacer with i managed to round off, so now i have to go to napa and get the reverse sockets and get it stripped off, just one of the many bumps in the road i plan on getting myself into, for the throttle body, how to you disconnect it from the car, i have everything on it taken apart and its layin in the engine bay but i can slide the round part inside of it out to get the actual throttle body off. Thanks for the suggestions it will make this go a lot smoother, once i get the upper intake off im going to start taking pictures to post here.
hmm
pull the engine, rebuild it from the bottom up, paint er purdy
SuperFord Profile
Support safe sigs
