{Carbswap} Say good bye CFI!!!! :banana:
    Ah, ok then. I was thinking you had a stock-ish cam. In that case lower vacuum is probably to be expected. Whats your timing set at anyway?
      12*BTDC for timing, Sounds about right. I might try 14* and hook up the advance for the hell of it.
      Hey Pete, you can clean up the wires for me only if I get to swap the carb onto yours and put your beloved cfi system in the trash
