Day one of the 4bbl swap is done. I started kinda late on it today so I didnt get too much done on it. I pulled the gas tank and painted the one I am putting in and made the sump modification to it. I got to get a way of bolting the straps to the bottom brackets since it doesnt use the pin like in Blaze's archive and the straps from mine are rusted away. I took off a bunch of old fuel line and started removing the stuff from the motor to get at the cam. I got the radiator, a/c condensor, cfi body, alt, coil, egr, map sensor, those soleniods from the valve cover, and a bunch of hoses and wires.
Tomarrow I hope to get the tank in, run fuel line, put in the new cam, timing cover, fuel pump and maybe put on the manifold(Thanks again TommyN!). Depends on how cold it is tomarrow to how far I get. Then sunday I will run the cables, wire it up, set the timing and see if it will fire.
