Aluminum driveshaft?
    It dont fit. Length is the same but the yoke that bolts to the pinion flange is way bigger. Cant even see the bolt holes. So if you pull one at the yard, get the flange too.
    1989 Grand Marquis LS
      Just swap 'em. That's what I did with mine...I had to because I didn't get the flange.
        Too lazy and its not that important. My u joints are good and the steel shaft I have is a stronger than stock aftermarket piece. Weighs at least twice what the aluminum does.
          i gotta find me a aluminum shaft i want one bad...
          The Best
            Originally posted by Southern_Pride
            It came out of my 90. Dunno if its factory or not. Ill look later and take pics.
            lets not forget 90' Town Cars were the bastard childs for the new parts. It could be that driveshaft is 91+ panther spec.
            I saw an article by a guy who swapped one into his box, he had to use the box yoke and a special U joint in the rear to mate the shaft to the box yoke.
            Dont ask me for that part number though....
              It was a 90 grand marquis. The tranny yoke works and the length is good. The one that bolts to the pinion flange is goofy.
