It dont fit. Length is the same but the yoke that bolts to the pinion flange is way bigger. Cant even see the bolt holes. So if you pull one at the yard, get the flange too.
Aluminum driveshaft?
1989 Grand Marquis LS
Too lazy and its not that important. My u joints are good and the steel shaft I have is a stronger than stock aftermarket piece. Weighs at least twice what the aluminum does.1989 Grand Marquis LS
Originally posted by Southern_PrideIt came out of my 90. Dunno if its factory or not. Ill look later and take pics.
I saw an article by a guy who swapped one into his box, he had to use the box yoke and a special U joint in the rear to mate the shaft to the box yoke.
Dont ask me for that part number though....Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
It was a 90 grand marquis. The tranny yoke works and the length is good. The one that bolts to the pinion flange is goofy.1989 Grand Marquis LS
