Aluminum driveshaft?
    Ya think It might give any better gas mileage. I got one in the shed and cant decide if its worth throwing in.
    1989 Grand Marquis LS
    you will need the extended tailshaft housing.
    Do it. you wil have slightly better acceleration, better gas milage, higher criticl driveshaft speed, less weight overall. A steelshaft and u-joints weighs about 20#s an aluminum shaft with u-joints weighs 10#s
      You sure the tailshaft housing is different on a AOD? I thought it was just the newer cars. I have the housing to if its different. Ill go measure after while and see.
        I dind't do anything but swap the DS's out. The length was the same...
          What drivewhaft did you all use?
            The one the guy gave me....think it was out of a newer vic. All I got was the actual shaft, no yokes or u joints.
            It lessened vibration quite alot. Although I found that the yoke and the bushing are pretty much trashed on my car.
              It came out of my 90. Dunno if its factory or not. Ill look later and take pics.
                If it's out of a vic and going in a vic it'll fit fine.
                  i'm still searching for an aluminium towncar shaft
                    Is the towncar longer? Id be willing to sell it but shipping would be high.
                      I don't believe it is. It is my experience that the tai shaft to the tranny is longer. But it could be the difference in length could be split between the driveshaft and tranny tailshaft, but I know for a fact that the TC tranny tailshaft is longer.
                        The wheelbase is about 3" longer. What that means for the underside is at least a longer tailshaft/tranny and driveshaft, anything else im not sure
                        '80 Town Coupé
                          I think they are both longer. Seems to me I've seen a pic of a Vic and TC driveshaft next to each other and the TC shaft was about 2" longer.
                          Just curious, do the Vic driveshafts have a rubber isolater ring around the front yoke? The one out of xxx's TC has an arrangement just like an engine's harmonic balancer with a rubber isolated steel ring around the front yoke area. My car doesn't have this, but I also have fatter U joints because of the tow package.
                            :stupid: Someone posted one up here a couple months ago
                            Nick
                            88 Colony Park LS
                              Scott posted that pic, man, Id love to find a aluminum shaft for my towny. I want to see how much a custom one is. Were there even any stock aluminum shafts on TCs anyway? Once spring rolls around I want to hit up this yard out in bfe see what they have.
