4bbl swap parts
    Originally posted by Mercmarquis
    So, very stupid question, If I buy 3/8 aluminum fuel line, how do I plumb it to the tank and the fuel pump(which is a 3/8 fitting)? I can buy fittings that I flare on each end and connect them right? They make adapters from the regular -8 or -6 to 3/8 or whatever. I dont want to use rubber line as much as possible.
    Don't screw around.......use AN fittings.
    female fitting
    male fitting
    Don't use regular rubber hose and clamps. Use Aeroquip push-lock (socketless) braided hose and AN fittings.
      I ran new fuel lines when I converted my 90 Mustand to carb. I ran pre-flared 3/8" hardline and unions that you can buy at the discount auto store. That fancy braided line is nice, but not really necessary.
      Tom
        Good point......don't bother with aluminum line unless you are willing to spend the cash on the proper fittings. Just use steel line from the parts store.
          aluminum line is easier to work with but if you are not carefull it can crimp on you in a bend. steel is a little harder to bend but doesnt crimp as easy.
            Do I need to buy a fuel pump eccentric on my motor to run a mechanical fuel pump? Or does a cfi car already have it?
              Never mind it already has one.
                It does? Funny. I was thinking the EFI cars wouldn't have it in there already. Some of them didn't have the boss in the timing covers for the pump either. My 86 motor didn't have the boss, my 88 HO has it, but the hole isn't punched through and there is no eccentric on the cam gear. I guess maybe some of them had it and some don't?
                  Mine has the boss too, but not punched either, cfi motors are very close to the carb motors. Since the 88 has a roller cam I guess ford would bother putting eccentrics on the roller cams since they were all fuel injected.
                    Mmmmmmm...fresh parts!
                    Well it's coming along nicely, I need a few more parts and I will start this friday afternoon hopefully
                      Nice!
                      And for the record, I think your carb swap will be faster than mine...
                        nope, you got a 2dr and 3:08's and a great exhaust.
                        I got even more lbs and crappy 2:73's with stock exhaust mainfolds.
                          Get 256 ucks, get the headers and offroad H
                          Also, I have 28" tires, so i'm closer to 2.73s indeed
                            In due time, I got to replenish the funds after this.
                              That's cool...
                              you already have duals, don't you? I forget what mufflers...
                              And how loud are they now?
                              Expect them to get louder :evil:
                                :evil: :evil: :evil:
