4bbl swap parts
    Yeah I know, I will probably will get the one from Tom, also I am getting a cam which would match the torker 2 if I got, and it is only $50. Summit + crane cams are only 50 bux, the one I will end up getting will be around 276 duration which might be too much for me or a smaller 266.
      duraspark II is what you want
        Originally posted by Mercmarquis
        I think I found the right distrbutor .
        You can get a reman for only a few dollars more than that dist. w/shipping.
        Get one for an 85 Mustang 5-speed if you are going to run a roller cam.
          I'm not running a roller cam, 85 CFI uses a hyraulic flat tappet cam. Can I still use an 85 5sp stang distributor
            I wouldn't. The steel gear would chew on your cast cam
              Thats what I was afraid of, Btw where are you finding reman distributors for like 20 bux?
                Let me be the first to commend you, mang...
                Another 4bbl swap!! :evil:
                -GMGT
                '80 Town Coupé
                  :ahem: 4bbl + Cam
                  This should be a ton of fun! :banana:
                    They are $35-50. Even if you get that one for $20, and pay $10 shipping, you are almost to the cost of a reman. Used just doesn't make $sense unless you are getting it at a bone yard for $10.
                      I see your point, I'm gonna check the boneyard monday hopefully for a distributor and possibly an entire duraspark ignition.
                        Bout time to see we talked some sense into ya
                          Alright this should be my final list:
                          1. Manifold
                          2. Carb
                          3. Fuel Pump
                          4. Duraspark Distributor- junkyard, ebay
                          5. MSD or Duraspark ignition box- Junkyard, or ebay.
                          6. Coil- MSD or replacement from NAPA
                          7. Lokar Tv cable
                          8. 3/8 Fuel line
                          9. Fuel bowl sight plugs
                          10. 2 ft 3/8 steel line
                          11. Cam- I might not do the cam cause I wont use it on my roller block.
                          12. Timing chain
                          13. Compression AN fittings
                          14. Fuel pressure gauge + filter to prevent flooding
                          15. Coolant
                          16. Water pump
                          17. Heater hose
                          18. Valve cover gaskets+ carburetor gasket
                          Now I must decide whether or not to do this, If I put this all together and find that nothing works, I will be in deep shit as I need my car. The only thing that would be a concern would be the carb tuning (easy enough) and wiring the ignition. I'm leaning towards MSD because that way I wont have to deal with the duraspark being toast and my car not running. Any thing else? Will I need to run a return line with the mechanical pump? I know I'm asking too many questions but, I need to be as close to foolproof as possible.
                            those compression an fittings will only work on other AN fittings (read $$$) i am using those since i am running an Aeromotive FPR (read $$$) you can get by with just hose barbs and work clamps, although id not reccomend doing that.
                            as for the MSD Here a local guy is selling one just back from MSD for $150. I have meet him and he is a pretty good guy.[/url]
                              So, very stupid question, If I buy 3/8 aluminum fuel line, how do I plumb it to the tank and the fuel pump(which is a 3/8 fitting)? I can buy fittings that I flare on each end and connect them right? They make adapters from the regular -8 or -6 to 3/8 or whatever. I dont want to use rubber line as much as possible.
                                it depends on what fittings you need to connect to.
