:Ebay: Another set of possible long tubes that might fit
    Granada or merc monarch headers. I wonder if it would fit one of our panthers? The guy says they are discontinued in the description. What do you guys think? They sorta look like the ones for the torino though.
    Interesting!!!
      Its only up to $30...
      Im feelin lucky...
      -Matt
      1968 Fairlane 500 - 1998 Camaro Z/28
        Do you think they might fit? I think that they might clear the crossmember. I wonder if they are to wide and will hit the steering shaft?
        I think I might try them, I dunno yet.
          If they are for a Fox grenada then i bet that the number 8 tube goes over the steering shaft.
            So that'd mean it will clear it just fine?
              If they are designed to go over a fox steering shaft they will not rfit
                I looked at some of the older mustang , falcon, monarc stuff before I went to shorties. They ran right into the engine crossmember. The closest fit and probably would have were long tubes from 84 to 88 or what ever but they were not designed for a auto trans. Looked as if they would fit with some minor trimming aroud the front gusset for the lower control arm mount but the dang tranny was in the way. If they only did some long tubes for the AOD mustangs
                  1975-1980, The tubes dont look like like they go over the steering shaft.
                    Those are the older Granada's not the fox chassis ones. They use a chassis that I think is based on either the 65-66 or the 67-70 Stang chassis.
                      I dont think I will have enough cash to try them and find out they wont fit.
