are the TPS for the mustang and for the towncar the same? If I have a mustang TB on should I have the mustang TPS as well? Currently I am using the towncar one.
TPS sensor question
TPS sensor question
The pigtails are identical, but they have different Ford part numbers and different aftermarket part numbers. Other than the pigtail, they appear slightly physically different.
I would stick with the Mustang TPS on a Mustang throttle body and it will plug into your harness just fine..
i'll probably get flamed, but i would use a new tps..........i had trouble getting my car started after the ho conversion.......the tps that worked on my lopo, and i could'nt start the ho.........got a tps from napa for a 86 towncar........been perfect since
scott
I'm using the original 86 lopo one on my HO body. The one from the HO body kinda got mashed by accident :drug: For some reason they don't take well to being clamped down on a milling machine.86 Lincoln Town Car (Galactica).
