Some Questions.
    Some Questions.
    So some quick questions.
    When the car is idling in park the car surgues.
    Thermostat?
    Doing this for as long as I can remeber, when the car is given a quick jolt of gas from idle, it chokes and then goes. Still havn't gotten an asnwer on that.
    1989 LTD Crown Victoria LX.
    -3.73s' w/ Track Loc - KYB GR-2 Shocks All Around - TRW HD Cargo Coils Rear - Moog Front Coils - 1 Inch Rear Sway Bar - 4.6 Lower Air Box- Stock Headers - Off Road H Pipe - Turbo Mufflers.
    4 Door Muscle
    Supermotors
    I'd think IAC or TPS. Possibly vacuum leak.
      Mine does that too, has been since I put the motor in. Vac leaks in my case, and I'll bet yours too. Check the soup can, the parking brake auto-release, and the line that tees off the cruise and runs down around to the smog pump area. I've also had the evap canister line that feeds over by the battery get cut by the belt. TPS and IAC are also very possible, but its still a good idea to check out your vac system, especially on the common leak areas.
        Every CV/GM I've ever driven did that. It's just something to accept.
          None of mine do it... :P
          '95 Ford Bronco XL -
          sigpic :rebel:
            many things will cause a idle surge, vacuum leaks are a primary cause.
            Checking the ECM for codes will narrow down if there are any sensor faults.
              I can't chek the codes.
              Hmm. I'll double check all the vacumm lines. I acutally broke 2 and replaced them. Maybe somewhere else.
              Thanks.
              4 Door Muscle
              Supermotors
                Yes... you can check the codes. use a test light or analog VOM.
                  4 Door Muscle
                  Supermotors
                    Originally posted by BlackHawkA4
                    Do some searching on checking the codes or buy a shop manual or EFI bible. All the info you need is in there. I have 3 different EFI books, 2 of which are considered the "EFI Bible"
                    http://www.booksamillion.com/ncom/bo...3013&ad=FGLBKS
                      it appears I have to do EVERYTHING.....
                      http://www.troublecodes.net/Ford/
                        There's no 5.0 there.
                        4 Door Muscle
                        Supermotors
                          Follow those directions, you have those same connectors under your hood, go pull your codes
                          '80 Town Coupé
                            You can't be serious. :drug:
                            Follow the EEC-IV instructions, there are no special steps for the 5.0L
