because there are two sumps. the front sump is there to clear the oil pump. the rear sump is where the majority of the oil is stored. YOu have to drain both during an oil change
Because there are two holes. If there was only one plug, the oil would leak out the other hole.
Hahaha that's good
Nick
88 Colony Park LS
