trying to add picture
    site will not load properly on any of my three browsers.
    "In an insane society a sane man would appear insane." --Spock to Kirk
    2008 GM LS in Smokestone Metallic
    I did get this loaded but the page to do so is a giant mess. sorry. the attach point on this car is farther back toward firewall than on most cars that need a 19".
        why does your TV cable have a weird spring between the end of the cable and the plastic stem?
          Yeah... that spring shouldn't be there. If the plastic won't stay out to support the cable, there are mods you ca do to fix that. The trick I used was to pull it out to where it needed to be, "latch it in place" and then put a split rubber hose over the plastic and clamped it in place with a tiny worm clamp. That held it in place perfectly well for several years before I sold the car.
            thank you. this is my nephew 100 miles away. I do not know what that lower cable n spring is for, cruise control maybe? will pass this on to him.
              That should be for the transmission. However... all of this said... IF it's working and not shifting like a lazy sloth, just leave it be. If it ain't broke, don't break it.
