Hey Y’all! What up! Newbie Sean here!
Can’t say how AWSOME this forum seems!
I wanted to post here and try and get as much info as possible as I’m planning to swap out the motor in my new (to me) 1986 CV. I have searched endlessly as there seems to be loads of info on the web for swapping a Ford 302 in general. Mostly seems the reverse scenario of guys putting CV motors into trucks. Found a few stang threads too…
The car is really clean, at least for one north of the wall here in Canada. Has original 113500 kms. However the engine has developed some bearing noise, and I assume its only a matter of time. I don't know much of the history, but I imagine it ended up in the hands of someone who failed to maintain it. I scored a lower mileage 1994 F150 302 drop in motor from a reputable wrecker, with a 90 day warranty. My plan is to strip what's needed off the CV motor and put it all onto the truck motor. I’ve never done this before - reason for joining…
The upper and lower intake I believe is required in order to clear the hood, but I am unsure if all the accessories are required, or the flywheel.
Before the motor goes in, I had also planned to do the engine mounts, rear main, oil pump, and pan seal. Mainly wondering what else I should consider?
Is there by chance any aftermarket upper plenum that would bolt to the lower truck intake manifold? Currently my only upgrade is some BBK equal length headers.
I am really new to engine swaps, so id really appreciate any and all input. Plan to label everything that comes off. Hoping it’s straightforward enough. Will plan to leave the AOD attached….
Some time ago I replaced a 4l60e on my impalla SS, so feel like I'm up for a challenge to get this box going, as I do plan to daily as much as possible, weather permitting…
A picture says 1000 words..
(not sure new members can ad pics)
so here goes:
I think shes worth saving, so I'm all ears!
Many Many Thanks in Advance.
so here goes:
