FIXED!!! I set the timing at 0 degrees instead of 10 degrees btdc. The dang balancer was rusty so it looked right the first time, plus I was frustrated and it was dark. lol
On the bright side. I figured out that if you set the timing at 0 degrees you can make a non-HO 302 run on 351 firing order.
