Thx Frisky
Fuel Pump stays on & hesitation under load and idle
Sounds like the relay is bypassed. The relay socket should have constant hot so if it's bypassed, that would cause constant hot direct to the pump.
yeah something is shorted. Only place a hot and the fuel pump feed should be anywhere close together is in the socket itself but someone could have bridged those. Likely if its going to exist, it will be right under the relay in the socket area or very close to it.
if the ECM was b0rked, it would still stop the pump if you pulled the relay. the only thing the ECM can do is ground one pin of the fuel pump relay. If the relay is out, whatever might be happening with the ECM or wiring to/from it will not matter. Someone has jacked it up on the power feed side.86 Lincoln Town Car (Galactica).
GOT IT. Whoever said fuel pump was jumped was correct. While attempting to fix the stalling out poor running issue, I changed the ignition control module and I screwed up the timing. The car was towed to a local mechanic shop to get the timing issue fixed. Well I called them to ask them if they altered the fuel pump at the shop and the manager seemed confused. However today while tracing wires I found this wire sticking out of a harness(see picture). I pulled it out and the fuel pump shut off as intended. Thanks so much for all your input guys huge help.
Fuel pump is sorted out, but still runs rough so I’ll still continue to search for vacuum leaks.
That's the fuel system priming port. You should ask for the plug back that fills that hole so the connectors don't get full of dirt.
Just remembered... that plug may be there on the inner fender as I think it has a push in fastener (christmas tree) on the back that holds it down. I'll try to look at my wife's car when I get home as it has the same thing.
so does that jump the +12v contacts then ? The one in the self-test connector grounds the relay same as the ECM does, so it won't run the pump with no relay installed.86 Lincoln Town Car (Galactica).
Yeah... this one jumps the 12V hot to the wire to the pump. Can be run when the car is off. A service port so to speak.
thats actually quite useful. The old style one had to have the key turned on for that. No +12v to the relay coil without the ECM relay pulled.86 Lincoln Town Car (Galactica).
