Engine Out Service
    The problem with trying to thread bolts in there is usually the holes are so packed with carbon you can't actually use the threads. The more sensible way is to take that crossover pipe, cut the ends off, flip them over, and bolt it back on as a blanking plate. That gets around having to try and get a bolt in there. Not so bad when you have the engine out and can use a tap to clean the threads but in the car, forget it.
    +1 on the double roller. I think I've got a Cloyes on mine. Not stupid expensive but not garbage either.
      Well if that works too, cool. It's free!
      2005 Volvo V70 Bi-Fuel
        if you want to spend money on new gaskets you can, just in case zero cost bothers you too much
          I'll give the carbon-filled threads a shot, just because I'll have the engine out and I don't know if I may someday have to reinstall that crossover pipe.
          Gaskets and parts have been ordered. Picked up the Cloyes 9-1138 "Street True Roller" chain set. Went Fel-Pro on all the seals and gaskets, one piece rubber for the oil pan. Gates 43050 cast iron water pump. Amazon and our credit card were running some sort of promotion, so it was all 50% off.
          I'm still going back and forth on whether to pull the engine and trans as one unit or one at a time. I feel that separating and joining the two out of the car would make things a lot easier, but getting enough clearance in the engine bay could be difficult. Has anyone on this forum pulled them together before?
            I've always removed them together. Clearance isn't a problem as long as you have an engine hoist thats tall enough, and you have an engine leveler. I removed my hood to take them out- but according to others you dont need to. It's only 4 bolts so i thought it worth it
            -Phil
              Having an engine leveler looks like an important part of the puzzle. I spoke today with the guy who runs the Auto Craft Shop and by his comments I'm wondering if they don't have one. I might stop by Harbor Freight and pick it up just in case.
              The fenders on the Panthers sit low enough and the engine bay is pretty generous - I'd imagine any engine hoist that could pull from a truck ought to be more than good enough for my car. The whole trick seems to be getting the engine to tilt back and then level out as you snake the trans out from its tunnel.
              If not using the brackets on the front and rear of the exhaust manifolds, what do you secure the hoist chain to on the engine?
                I have always pulled the engine and transmission together. Much easier in my opinion. If you are going to buy a engine hoist, or engine stand, DO NOT GO CHEAP. Harbor Freight in my opinion I would not trust. I bought my hoist and stand many many years ago in the San Bernardino area from a company that specialized in making them. Very heavy duty. As far as getting the engine and trans out, You will have to remove the hood. Clearance should be no problem then.
                If you have to comply with smog regulations or if it has to pass smog when sold, I would not mess with any smog stuff. Ca. is brutal with smog. Just my opinion.
                  Just dont use a engine stand with a single front caster wheel. You're guaranteed to dump it moving them around. HF junk works fine on SBF's it's not like your trying to hoist a cummins.
                  Personally, I leave the transmission in. I dont have a leveler, and dont want the ATF shower from the tail shaft. Just support it under the pan, you'll be good.
                  I pull mine from the side fender now, with hood off since most affordable hoists even with the arm extended and chain out the end rather than the slot, you still ram the cylinder into the bumper and are a few inches forward of getting the motor straight onto the mounts. (MGM specifically, since the nose is longer) You kinda of glide it all together while it lowers since the arc of the hoist moves it back as it drops.
                    Agree will not having one caster wheel in front of engine stand. Dangerous
                      I've never had anything that would lift an engine high enough to do it with the trans. Keep in mind a Lincoln is like a foot longer in front than a Vic too so its more of a pain in the ass. Standard engine hoists are a bit short. The front plate on mine was pretty bashed up from doing the engine. I think the last time I ended up sitting it down out of position so I could extend the chain enough to let me shove it back far enough to sit down on the motor mounts. If you have an overhead XY chainfall system I can see it working with the trans but I really have no idea how you'd get all that out with a standard engine hoist.
                      never tried it from the side but thats probably the better way to go. I can tell you that from the front sucks.
                      keep in mind the weight, most of those are rated for 1/4 ton all the way out, which is only 500 lbs. Thats pretty much the weight of just the engine. The trans is another ~200.
                        We are talking 3 things here, engine cranes, engine stands and engine levelers. I had a old heavy engine stand with one front leg and no problems with that monster but something light and new like from HF could sure be a problem.
                        It has been a loooong time but I thought I just hand raised the tail of the tranny while pulling the assembly out. Does take at least two people that way though.
                          I don't know anything about the engine stands at the Auto Craft Shop, but I did see their hoist is an old Pittsburgh. Hopefully it's one where the longest reach is still rated at 1/2 ton.
                          I've been driving the car around town the last couple days and I'm scratching my head over the coolant leak. I know the freeze plugs are on their way out - I can see fresh coolant drops around them and below on the side of the block. And last Tuesday the radiator was about 2 inches low on coolant. But in the last two days I've checked the radiator the level has been right up at the cap. The only difference was the time it was low it had been parked on the street overnight.
                          So I might not be losing as much coolant as I first thought. The engine still ought to be resealed, and with a kid coming in January there won't be a better time than now. But I am a little confused.
                            Before using a either an engine hoist or stand, check the welds for cracks and the chain for any stretched links. Bolts on the engine stand need to be grade 8 (I think). I have seen those material defects . Equipment is made cheap now. I know my comments are on the cautious side, but better to be safe than injured or your motor damaged from being dropped. I know I used a plastic plug on the tail shaft to prevent fluid from spilling all over. Last time I did that type of work was in the early 90s. For me it was not cheap but worth it to buy the right equipment.
                            It is LOTS of work but some people remove the header, core support , radiator etc. Then R&R of motor and trans is a breeze.
                              In my experience, sometimes coolant leaks don't happen until it's cold outside.
                                I can buy that, but in this case what must've happened was no leak at all, or at least not nearly as much as I thought. I think some coolant must've passed into the overflow tank and not returned overnight, but was later sucked back into the radiator on some subsequent trip. Because I never topped off the coolant, and it didn't 'unleak'.
                                Perhaps the overflow isn't drawn back in until the engine gets hot enough to start circulating coolant?
