Fan clutch options
    Fan clutch options
    Does anybody with a parts manual have a breakdown on what the different factory fan clutch part number's were (tow/police/hot climate/etc.)? I can dig them up on RockAuto but each of the aftermarket ones list a bunch of different Ford PN's. I prefer to buy NOS on Ebay and the like so knowing the exact Motorcraft PN is key.
    Thanks!
    1986 Country Squire
    1969 Mercury Cougar
    1960 Land Rover Series II 88"
    can you get me any of the OE numbers? Makes it easier to find in the master parts manual
      here is a part number for one: E1AZ-8A616-A
      From this:
        Just the listing for the Hayden 2710 clutch (1987 5.0L "Standard Duty") lists E0MY8A616A, E0WY8A616A, E1AZ8A616A, E35Y8A616A, E3TZ8A616J, E45Y8A616B, E4SZ8A616A, E5AZ8A616A, E5AZ8A616B, E6AZ8A616A, E6AZ8A616B, E7TZ8A616A, E7TZ8A616G, EOMY8A616A, EOWY8A616A along with a bunch of 60's and 70's part numbers. I've seen F series PN's from the 90's trucks list with the same 8A616A/B base number so I don't think there are too many variations, I just don't understand why they would have reissued these numbers every year for an unchanged part.
        1986 Country Squire
        1969 Mercury Cougar
            Every fan clutch will have the same base number. I just needed one to find it in the manual, saves the bother of trying to find it in the listing. Here you go, direct from the 80-89 master parts manual, 1993 final publication date. Beware what you say about not thinking there are too many possibilities.
Name:	fan clutches 80-89_1.jpg
Name:	fan clutches 80-89.jpg
            Sometimes the part number changes because the part changed in some meaningful way, sometimes its just a supplier change or some other trivial difference that doesn't actually matter. Unfortunately the parts manuals don't bother to explain exactly what the differences are.
              Interesting, looks like they changed year to year more frequently than I would expect and just kept 2 variations per year in different applications. Thanks for all of the info! To Ebay I go!
              1986 Country Squire
              1969 Mercury Cougar
