1984 Town Car TS-58 temperatur sensor wrong resistance? Gauge shows almost HOT
    Hi,
    Gauge peaked up short beyond the "L" in "normal" at the gauge face with the TS-58 on my 2 hour trip back from my donor car visit on the Autobahn. It showed constantly around "M" during the 75mph ride in the morning however. After some errands at the donor car´s place and a lunch break it peaked at almost HOT when we drove back.
    is the Standard Motor Products temperatur sensor TS-58 prone to show a hot reading?
    Had I better used the Motorcraft brand?
    1984 Town Car, analog instrument panel.
    Air in the system will cause that issue. You get bad flow with excess air (typically in the line going to the heater core from the pipe near the thermostat). Getting these bled properly can be a pain sometimes. Bad radiator cap can cause this issue as well. Bad cap will let coolant out when it should be holding it and allow air back in when cool due to there not being enough coolant in the overflow tank to be sucked back into the system. Bad fan clutch will cause it to heat up when not at speed. Check at operating temp by shutting off the engine and watching the fan. If it makes more than 2 revolutions, the clutch is shot and needs to be replaced.
      Thanks,
      I´ll check the fan when I drive her home this evening.
      Radiator shows flakes of "leak stop" and I must admit I produced a hairline crack to the aluminum intake manifold when torqueing the new temp sensor. Shame on me. I could kick my a** for that. That hairline crack has minimal coolant leak when running. Just that a tissue napkin gets a moist spot if you touch the crack.
        Yeah... the crack will let air in. Need to fix that. And if you have flakes of stuff in the coolant, you need to flush that system. Crap built up on the coolant channels will prevent the coolant from getting the heat from the engine as effectively as it should.
          Coolant flush is on the to-do-list already and we´ll try to fix the hairline crack.
          Fan clutch is working btw.
            The other issue could be a sticky thermostat. That's the exact issue I had with the last thermostat that went bad.
              Something I'm going to add here without too much analysis of the problem: the temperature gauge in my 84 Town Car cluster is faulty, and over time gradually reads higher despite the actual engine temp being consistent.
              I do not expect this is common, widespread, or specific to 84, but it is a possibility to keep in mind.
              Most likely my problem is specifically with the Instrument Voltage Regulator causing out of spec voltage, but I never diagnosed it further, just determined "the gauge was bad", put in a mechanical gauge, and left it alone since that. The car hasn't been driven in a while now.
              | Junkyards
                My '88 has the inverse issue, it reads colder than it actually is until it starts to overheat. The pointer only goes halfway through the "A" in Normal. I've ohmed out the sending unit and it was correct for 195F or whatever the book says it should be. I've just left it alone.
                  IVR problems will also make the gas gauge read stupid. Its a mechanical device, basically similar to an old bi-metal blinker in operation and over time those parts lose tension and it goes stupid. You can buy modern replacements that are not mechanical, its just a simple fixed voltage regulator in the original package so it plugs in and gives steady voltage instead of the pulsed output the original did.
                    Still no time to address the hairline crack at the temp sender, BUT I flushed the whole system two times, took off the thermostat (US-made), checked it for proper operation which it did and changed the TS-58 sender for a genuine Motorcraft one I bought. Rockauto had sent me a wrong Motorcraft Thermostat so I had to reuse the old one.
                    Gauge shows acts normal again with only sometimes pegging up to "L".
                    So I DO think it is an air bubble that gets stuck under the sender from time to time. Usually the needle drops back after a hard turn (again indicator for air bubble)
                    The thermostat wasn´t clogged or such just dirty with rust - don´t ask what that coolant looked alike when I drained it.......
                    Right now I´m running plain water and will do further flushes untill I see the drained water becoming less dirty.
                    Then I´ll change for distilled water and Motorcraft green coolant.
                    Oh, I changed all hoses for new ones while doing the flushes.
                    Backflushing the heater core was interesting too........lots of brown water.....
                      While changing a leaking fuel hose under the engine I noticed that the heat riser valve was disconnected from the actuator rod, leaving the plate inside the valve to flap to and fro. Could this have caused the fluctuating temperature by blocking the exhaust of one bank?
                        won't help any thats for sure.
                          Hi, that must´ve been the culprit. Since reconnecting the rod the gauge showed normal operation with the needle straight in the middle.
