Core plug
That is a block heater.
Do you want a block heater?03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
The threaded hole below it should be the block drain plug. It's down inside that hole and should be a hex drive plug.
As for the block heater: clean out the hole and you can take the broken bits of the bolt clamp and get some flat bar about the same length but about 1/8 thick and thread it or weld a nut to it that fits that bolt and put it back in. If there's any rubber seals for the bolt hole or outer edge, you may need to replace those.
Or just get a casting plug (freeze plug), make sure the surface is dry on the walls of the hole, put some sealer around the plug and knock it in.
problem with the core plugs is that you usually can't drive them in with the engine in the car. Most of the time the angle is wrong. Possibly why someone put the heater in there to begin with, especially if it doesn't have the cord with it.
Expanding rubber plugs exist for this reason. The block heater looks like the same kind my diesel had, and has the same failure. The "wing" that retains it didn't have a hinge, it was just bent into a V originally and the nut looked basically like a Chevy bow tie. The screw simply pulled the bow tie into the V and flattened it out. Unfortunately that makes the metal at the point of the V flex and it caused a stress crack. Mine failed when I pulled it out to replace the leaking O ring. There is also a rubber washer under the head of the screw, but without that wing none of that matters. It will not hold in the block without it. Not sure if you've got enough screw and depth to get away with a solid piece of steel with a tapped hole or what.
if you can just replace it with a standard core plug, do it. Clean the hole out real well, wire brush it so its down to clean metal, and hammer the thing in there. I've never used sealer but if you want to, use something thin line aviation sealer. No RTV or anything thick like that. They hammer in with a socket that just fits in the core plug, and they drive in until the edge of the cup is flush with the block. See your other ones for examples.86 Lincoln Town Car (Galactica).
they aren't ideal, but it makes sense if the only other option is to yank the engine to drive in a metal one.86 Lincoln Town Car (Galactica).
Originally posted by Mainemantom View PostMake sure you use a freeze plug made of the same metal as the others in the car.
My personal opinion is to stay away from the rubber freeze plugs. I have used them many years ago. Never liked them.Originally posted by gadget73 View Postthey aren't ideal, but it makes sense if the only other option is to yank the engine to drive in a metal one.1990 Country Squire - under restoration
