heater core restrictor
    Only way to get effective cleaning of water without choking the flow rate horribly is to have a lot of filter surface area.
      I what size is the recommended washer hole to use? If you go too small I'm guessing heat output will suffeR?
      -Phil
        Some folks use a cheap socket as a restrictor. So I doubt there's any need to worry about the hole size. As long as there's flow, you will get heat.
          Originally posted by WagonMan View Post
          Does a restrictor give you more heat? I put a new heater core in my 90 without ATC and I barely get any heat out of it. Even with the 195 degree thermostat. WagonMan
          Gives you less heat. When I replaced my core I used it since it was in the box and with all the hubbub about restrictors back then put it in. Removed it when winter hit for more heat. Never ran restrictors in my Generals, sure don't see any need for it with a ford.
