Replace MAP sensor vacum line
    Good point Gadget.
    I hope not. This one is very original from Arizona with low miles. It still has desert dust on it.
    The other 90 wagon is doing well, always starting. Very smooth idle and driving. Replacing the ECT did it.
    I saw that Bernie has placed the ACT at the back of the upper intake.
    My mpg did go up 2 mpg.
    Maybe more when I fill up again.
    The shifting is very subtle at low throttle but it noticeable at full throttle.
    When I have the transmission fluid changed I will look into the governor.
    I THANK YOU always for all of your help.
    Mike
    90 Colony Park LS with GT 40 heads and intake. HO cam, 65 MM TB, 67 MM EGR spacer. Has a 75 MM Pro Flow mass air sensor. Borla XS mufflers. 3L55. Shift kit, 2000 stall Tq convertor...Bilstein shocks, front and rear sway bars.
    90 Colony Park LS 64,000 miles all original. 3L55 tow package....front and rear sway bars.
    91 Grand Marquis GS....HO motor..Bilstein shocks poly bushings and police swaybars. This one handles the best.
    70 Torino Squire with M code 351 Cleveland 3.00 has Magnaflow mufflers. Hidden headlights and power windows. All original
