So, I'll get flack for this, but what are the repercussions of removing the EGR spacer on an 87 Grand Marquis, like, entirely. What does it do, and why did Ford put it there in the first place?
Much more importantly is this... in the center of the intake, or more correctly somewhat under the upper intake, there is a vacuum hose, mine had rotted off and I have it roadside rigged back on there. Obviously this is because the vacuum leak made my idle high and stupid. I didn't even know it was there until I investigated, pain to do with a hose that doesn't fit right and heat shrink to make it "fit". /I no longer have a vacuum leak. But, onto the question part.
What does the aforementioned vacuum hose do, and can I cap it off instead? Anybody have a vacuum diagram for these cars?
