LoPo 302, CFI, carb and emissions
    http://www.grandmarq.net/oldfuelinjection/page13.html
    self test process. Codes are also listed there. You need the 2 digit list.
    Yeah I've done that, but it doesn't tell how to do the engine running test, unless I'm stupid. I thought maybe the engine on test would shed some light on the obvious misfire at idle and so on.
    As far as I remember I had no KOEO codes after changing the TPS and EGR pos sensor. I didn't do a check after I got it from the mechanic.
    2005 Volvo V70 Bi-Fuel
      start the engine, then connect the ground to the STI.
        This is exactly what I wanted to know last summer, but it ain't too late even now.
        I won't need a code reader, great!
          They are useful, mostly because it gives you a number rather than a blinkenlight code but definitely not a must-have. I picked one up cheap but I didn't have one for years.
            Just make sure the engine is fully warmed up before running the KOER tests. After it’s warmed up I usually run the engine at 2000 rpm for a minute or two, shut the car off for 10 seconds, restart then begin the test.
              good point. You will get a fault for the coolant temp sensor if the engine is cold.
