Hey guy's. My valve cover gasket's are leaky. Look to have been leaking for quite a while. Not bad enough to drip on the ground though, just burns off on the exhaust. Anyways, I notice that on this engine, in order to do them the upper intake has to come off. Good time to put new vacuum lines on (hopefully that will settle the idle a bit when cold. (it surges a bit when out of gear))
So, been doing some reading online for the last couple of months and found that some people recommend getting a HO upper and throttle body if the old one has to come off anyways. Is this really all that worthwhile for a stock engine? Will power go up any? How about its effect on torque? I do have dual exhaust (with a little bit higher flowing mufflers, but w/ factory 1987! cats) so that may help a bit. Anyone have any numbers? If it's worthwhile, i'll do it. Those are some easy parts to pull off a junkyard stang.
Is there much of anything else, bolt on I should/could do?
Overall, I am actually satisfied with the power. Guess I'm used to low performance vehicles... This thing just goes with the 3.27 gears. May need a bit more for highway passing, but since I don't speed much I typically don't need to pass all that much.
