My 88 mgm
    Mine are down below the radio, honestly they are not visible when driving. I could lose oil pressure and I wouldn't know it. thats actually why I modified my sending unit extension and put the idiot light switch back in. At least I might see the light if something tragic happens.
      My 88 mgm
      Update so far trimmed the lower gauge pod almost fits perfect under the ash tray
      Also replace all 6 interior speaker had to trim the door speaker hole a bit, and put some dynamat around speaker. replaced the front door
      Also here’s a better picture of the Adtr rear control arm with my exhaust and aluminum drive shaft installed
      And my rear disc conversion I been trying to do I started buying parts rear disc (finally)
      My new diff cover. Carbon clutches are coming Tuesday. Hopefully next week I will order the gears and rebuild kit for the rearend
      When it’s done it will look like this.
        Nice!
          Got a brand or part number on the gauge pod? How much modifying did you have to do?
            My 88 mgm
            Autometer 15022 supposedly is for a hummer on top dash pad I figured I would just flip it around and trim it. [emoji23] it wasn’t so bad just made a little paper template of the ash tray. And cut it out with a dreamer. Trim check fitment and cut some more. But it came out good I think.
              Before I cut it up
              After trimming
                Nice
                  I like it.
                    My 88 mgm
                    Here’s a few picture of the parts I have for the rear disc swap, so far I still need the gears and axles seals. Not sure if I should just go ahead and buy new axles since it’s all out.
                      So haven't posted in a while but here's a few pictures of stuff that's been done to it.
                      Last thing I was working on was rearend but
                      Had a electrical fire that had to put everything on hold.
                          Ended up wiring in a 94 Vic under hood fuse box
                          Also had to rewire all wires in the front to headlight corner lights and alternator and battery wires which it was a pain
                            Looks like it will be in better shape.
                            Question on the rear, Is that a 28 spline carrier?
                              Well while it was all torn apart I decided to go electric fans also lol
                              I ordered the Lmr contour fans with controller and went to town.
                              Spacing was almost perfect only thing I had to do was drill top mounting brackets a bit.
                              I wired the controller inside the glove box which I think came out great
                              Wired all relays to fuse box which includes high and low fans and also. Headlight relays
                                Yes but since then I went a different route
                                Going with 31 spline now
                                Had the tubes welded.
