Hello all,
As mentioned in an earlier post, I recently changed the valve cover gaskets in my '91. While I had it all apart, I replaced the plenum gasket, throttle body gasket, EGR gasket, plugs, wires, cap, and rotor. Unfortunately, most of the vacuum lines are very brittle and in the process three broke (pics below) The green goes to the EGR valve, and I'm not sure what the red does, nor the white (smog pump?). The white line is on the passenger side.
The car idles high once warmed up, slightly rough, and the exhaust smells a little like unburnt gas/rich. At first I thought maybe I put the wires on the wrong spark plus, but they seem to check out. I'm beginning to think it has to do with the three broken vacuum lines (no check engine light yet). Any input is appreciated. Thanks for all the help!
