Hello guys!
I would like to tell you my experience past few weeks with my ´87 Colony Park 5.0 EFI.
in 2 different moments, the car suddenly turned off while i´m in movement. I consider this very dangerous since I lost many functions on the car or at least does not work properly (steering, brakes, transmission, etc...). My city in Chile has many hills and I don´t want to be in that situation when I´m in a downhill
After the car turned off, I try to start again and the engine runs again without problem, but with the fear that this occurs again. Today, after this second episode (the first one was about 1 week ago), I park the car, run the engine in parking for a while, and turned off again. start again with the key, and again the same after a few minutes. (no warning lights remained on in the dashboard).
For the record, I have a similar problem when I bought the car 1 1/2 year ago, but it was the Ignition module, apparently. So, 1 year ago I changed: Ignition Module (Motorcraft), Ignition Coil (Motrcraft), Spark Plug and maintenace to all the electric sistem. That time, the car turned off and won´t run again after the engine gets cold again, but now it stop is sudden.
My other problem is that the car stop when i made short movements, when I´m parking for example, could it be related?
Any ideas to begin the investigation of the problem, in the past your wisdom made a correct diagnosis!
Thanks and regards!
Thanks and regards!
