So I am checking to see (just in case) I do need to get a new vac coffee can (E1VY-19A566-A) The one one my '86 Tudor GM has only one nipple for the vac line that goes back to the dash tree, why do I see ones that are almost identical on E-Bay, but have two nipples on one end. Can this be subbed for the one on the car with only one nipple?....
Coffee Can, why do some have two "nipples"
For different vacuum routings. Cap off the extra nipples, you'll be fine. Also, it doesn't have to be the coffee can form. Any vacuum reservoir of decent size will work, you just have to mount it.86 Lincoln Town Car (Galactica).
Cans don't have check valves in them. That's a plastic ball Ranger/Explorer thing.
I was speaking of the single port cans. No clue about the 2-port cans. Those may have a check valve in them. I could see that if the vacuum source goes to the can and then to the cabin.
That part number pulls up what looks like the 2-nipple one. That one may have a check valve. I don't know for sure what the older cars used. You can use it, but just plug one port. You can also just use the GM ball as well (which is what several folks have done in the past).
The ATC ones are coffee can size, manual ones are Dinty-Moore beef stew can size. It will work, but if the system is leaky it may creep towards hot defrost more quickly than if you had the larger can. The reservoir on myy car is probably smaller in volume than the Folgers can but I haven't had any problems.86 Lincoln Town Car (Galactica).
I was sent the one with one nipple, and Green claims no internal check valveOriginally posted by sly View PostI was speaking of the single port cans. No clue about the 2-port cans. Those may have a check valve in them. I could see that if the vacuum source goes to the can and then to the cabin.
Vacuum reservoir shouldn’t have any effect on the blower motor speed. Lack of vacuum to the HVAC panel can affect air direction however, since the blend doors for vent selection and such use vacuum for those functions.
My Cars:
I think it can, actually, with the 89- vacuum ATC system, if a drop in vacuum results in a misbehaviour of the relationship between the interior temperature sensor and the blend door servo.
Zero vacuum = servo returns to full hot position.
Otherwise, vacuum loss would result in vent selection defaulting to defrost, so the air will stop coming out of the expected locations, also simulating the blower slowing down.
With ATC systems, the blend door position dictates the fan speed by some means. I never dug deep enough into the system to find out how it does it though.
