Fuel injector stuck open?
    So hey guys i got a 1990 grand marquis and its been misfiring on #8. I checked the codes while running and it gave me the usual egr and the thermal stuff that goes behind the heads which i blocked off when we rebuilt the block. Pulled the spark plug and its smells like raw gas and its black as sin. I checked the wires and even switched the wires and plugs from the other cylinders and it still misfires. Do y'all think the injector could be stuck open or maybe a burnt valve?
    Sent from my LG-LS997 using Tapatalk
    Sounds like possible stuck injector, but if it had no spark you'd get pretty nearly the same thing. If you've swapped plugs and wires thats probably not it tho. Fuel pressure test would help confirm. If it leaks down fairly quick its going someplace. A compression test wouldn't be a terrible idea either, if its got none it won't burn the fuel off.
      I also forgot to mention it only misfires at idle and when coasting or slowing down to a stop. At highway speeds it runs perfect
        As far as checking the injector, you could check with a noid light to ensure you have an injector pulse still. After that I would swap in a knowing good injector or swap around injectors and see if the issue follows or remains on your trouble cylinder.
        Like Gadget said run it through a compression test.
        It was mentioned to me a rudimentary way to check for a possible burnt valve condition was to hold a piece of paper about a half inch away from the tailpipe. If it gets sucked in and blown out repetitively, there's a chance something is wrong engine side. I've come to the consensus my '87 burned an exhaust valve and I experienced similar symptoms, but obviously in your case don't jump to conclusions just yet. I ran through quite a bit of asking questions here and troubleshooting before arriving where I did.
        When I ran a compression test I got roughly 10 PSI out of the suspect cylinder. Like yours has done, mine misses at idle or deceleration, but cruising along you can't really tell there's an issue. I did note a dramatic loss of fuel economy, however, going from roughly 15-17 city to 9-11 city. Highway mileage seemed generally unchanged and continued managing 19-21.
        My Cars:
          Thanks for the advice guys. Ill go check it next week when im off since i have her parked at my parents olace and it takes about an hour to get there. Will keep you all posted
            If you are experiencing a leaking fuel injector you would have hydrostatic lockup, I would think combustion chamber blowby meaning burnt valve.
              They can be stuck open and not have hydro lock. I had one on the old 89 where the pintel was obviously stuck open.
                What exactly is hydrostatic lockup? Never heard of it, ive only heard of hydrolocked
                  Same thing. The injector could be slightly leaky, not enough to fill the cylinder but enough to run too rich at idle. Internally its just a needle valve and a seat. Open one millions of times and both can wear enough that its an imperfect seal.
                    Makes sense. And if it helps any the motor makes a popping sound at idle and i hear hissing for a second or two when i turn it off
                      Alright so i did a compression test on #8 and it came out to 160. So def not a burnt valve. I am going to get a whole set of new injectors. Should i go 19 or 24lb injectors?
                        Unless you’re running a tune or a HO/Explorer swap at this moment, running a larger injector will not help you and would likely run worse. Stick with the 14 LBS injectors if you’re still stock. I got a set of eight remanned ones off of eBay. Avoid the Chinesium ones, they’re junk! I found that one out the hard way.
                        You may see listings for the four hole and single single pintle type injectors. Single pintle are OE, and four hole are technically improved design. The four hole ones supposedly have better atomization ability compared to the single pintle types, but I don’t know how much better it would be on our engines. I just stuck with single pintle ones when I ordered my remanned ones because they were cheaper.
                        My Cars:
                          yes, stock 14# injectors for the stock engine. 19 for an HO unless the ECM has been tuned otherwise.
                            OH yeah, couldn't you check fuel pressure once you flip the key off? I'm not sure but I thought these hold pressure for awhile so if you've got a leaking injector, you'll see pressure bleed off. Just my arm chair quarterback idea.
                            Like K wolf said about the injectors, I think I would just run OE single pintle.
                              Yes, definitely check fuel pressure. I bought a tester kit at harbor freight for pretty cheap and it works! Easiest place to start.
