Speedo cable and pressure regulator bolts?
    I took the speed sensor out of my trans today and the bolt snapped, does anyone know the thread size and length of that bolt?
    I'm putting a new fuel rail on, does anyone know the thread size and length of the three bolts that hold the pressure regulator to the rail?
    I got a new fuel rail a few years ago, took the regulator off for some reason, and lost the bolts.
    Thanks.
    The length is 3/4 inch (~20mm) IIRC. If you have at least 3 threads left on the bolt, you can size it up at a hardware store.
      I want to say the VSS bolt is M8 x 18mm or so.
      FPR I recall being fairly small, probably 10-32x1/2" or so. Might be 10-24, its been a long time. I do remember it being a socket head cap screw (allen head) though.
