Stall and misfire
    Stall and misfire
    Well I'm back here with a similar issue I had before...but it's changed. Originally I had a problem where the car would stall when sitting at a light and not restart. I ended up replacing a faulty aftermarket pickup with a stock ford one....
    Yesterday as I was coming up a small hill, under load, the car suddenly stalled. I've never had it stall under load. After about 2 minutes of sitting there it was able to restart. In addition I noticed at a certain load point it seemed to be misfiring. Initially when the car stalled I thought it may be my fantom ignition problem coming back from the dead, but with the misfire now I'm not so sure. Before the winter the carb was tuned using a wideband oxygen sensor and ran beautifully... I'm wondering if sitting caused some gunk to form in the carb...or what! I've driven this thing maybe 900 miles without issue...
    I've replaced literally every part of the ignition system save for the wiring (which ive tested) and the entire dizzy assembly. Any ideas?
    -Phil
    I'd start with the simple thing, fuel. Gas does not last as long sitting as it used to and definitely could've gunked up the works. I'd clean out the carb and see how everything looks/smells in there. Get some fresh fuel and see what she does.
      I'd run some hi octane gas, a can of Seafoam, and put in a new fuel filter. It's kind of overkill, but eliminates a hand full of fuel system problems.
      Sent from my SAMSUNG-SM-J320A using Tapatalk
      Back in the saddle again!
      2004 Crown Victoria Police Interceptor in Unimaginative Bureaucratic Brown
      Bone stock... for now.
        Welp, pull the float bowls and see if there's any residue. Typically though, if you've got gum the idle circuits & float mechanism are the first to show symptoms. With my carb, the float would stick and then dump all kinds of gas down the intake. I'm leaning towards ignition issue. Find a known good dizzy, swap and see what happens. I know you replaced the pick-up but that doesn't mean you couldn't be running into the same song & dance again...
        Edit: It just occurred to me.. Are you getting fuel? Is the pump working properly? Is the filter plugged? Does it run at all currently?
          Dead spot in the TPS? If you have an analog multimeter, you can check the sweep for opens/shorts. If the needle on the meter jumps at the same point, sweeping back and forth slowly, you've got a bad spot and it will be confusing the ECM.
            I'm pretty sure he's talking about the 82. Which is some aftermarket carburetor.
              Sorry I should have specified it's the LTD-S. 2150 Carb, no fuel infection. It runs fine. it just stalled out once, wouldnt restart for a couple minutes, then restarted. Fuel is probably 4 month old? maybe? Fresh fuel never hurt though. It conked out instantly, no rough running or signs of it stalling, it just conked out BANG!.
              At this point if it is STILL the ignition, i might as well remove the entire system and replace it with a brand new one. wire, dizzy, everything. And im not willing to do that. It could be the pickup again, or it could be any of the new pieces ive replaced. It's a crap shoot
              -Phil
                4 MONTH OLD fuel is enough for it to turn shitty used to happen to me all the time as creamy might sit for weeks to months. Get on the gas a bit and would miss and stumble. no issues with it any more using ACES 4 its a octane booster and the best fuel stabilizer i have ever used. whit it on one vehice that sat for 2 years started rite up and drove as it did when it was last run.
                  Just for S&G, if it persists try using a jumper wire to supply power to the ignition system, bypassing the key switch. I'm half wondering if you have an intermittant power problem that drops ignition power to the coil or box. Also if that resistor wire hasn't been replaced, it could be the issue. You can bypass that short term but its not good for the coil or ignition box to do it for long.
                    ah... the old one... yeah... +1 on the crappy electrical. Is there a relay for the ignition bits or is it just fused/fuselink through the ignition switch? If there is a relay... may need to pinch connectors and check for corrosion/crud.
                      pretty sure no relay
                        If carb is clean, I’m thinking spark is getting weak then nonexistent.
                        I have a spare duraspark box out of an running 81 if you want it for shipping cost. I used to carry it as a spare in my 82. It’s got the yellow colored plastic where the wires come out and three connectors. PM if you think you could use it.
