Short trips when cold has more to do with how thick the differential fluid you use and if its synthetic or not
Winter Vs Summer Fuel Mileage
The diff oil being thick doesn't help though. Synthetic is an improvement there. Also not significantly more expensive, so win.86 Lincoln Town Car (Galactica).
Interesting, i suppose it's good that I'm getting on par fuel mileage. I use 10W-30 synthetic oil. Being cold does not help at, all as mentioned...I don't think the car's even fully warmed up until 1/2-3/4 of the way on my normal trip when it's cold. If I went 65 and got 20mpg...it really wouldn't be worth the 2 extra miles I got to slow down, not to mention people trying to run me off the road at that speed!
I do wonder how its highway mileage would be with 3.08's or 3.27's. Probably not worth the trade off for many reasons, besides acceleration, I do more in city than highway. What was the
"standard" gear ratio for wagons without the tow package? I hope not 2.73s...-Phil
Synthetic specifically in the diff is what I meant. It flows better when cold.86 Lincoln Town Car (Galactica).
Originally posted by Brown_Muscle View PostInteresting, i suppose it's good that I'm getting on par fuel mileage. I use 10W-30 synthetic oil. Being cold does not help at, all as mentioned...I don't think the car's even fully warmed up until 1/2-3/4 of the way on my normal trip when it's cold. If I went 65 and got 20mpg...it really wouldn't be worth the 2 extra miles I got to slow down, not to mention people trying to run me off the road at that speed!
"standard" gear ratio for wagons without the tow package? I hope not 2.73s...Scars are tatoos of the fearless
here is how i figured how much economy in the wither was affected by rear gear lube.
Going to work would start the car. it had the climate control heating/AC. would let it warm up until the heater fan set auto would kick on. high idle choke mode dropped to normal after a very short period. Coolant temp at this point around 140* took much longer than choke mode.
it was 3 to 4 miles through city streets to the highway and would run it to work another 8 to 10 miles.
Coming home was just the opposite went through the same procedure to warm up the car but the entrance to the high ramp was was a block or less from were i worked.
used a lot less fuel going to work compared to going home. Changed the OEM fluid in my 87 to synthetic economy came closer to the same both ways.
Want to see the difference put some 80 90 wt syn and some non syn lube out in a cold winter day and try to pour it outScars are tatoos of the fearless
Open 3.08 seems pretty standard for most wagons from my findings, including my 90. The 88 is 3.27 open. I don’t notice a difference between the two.1990 Country Squire - under restoration
My 86 Wagon has 3.08 and the 84 wagon has 3.55
For reference and because I had to search it, Door Axel codes:
8 : Open 2.73
M : Trac-Lok 2.73
Y : Open 3.08
Z : Trac-Lok 3.08
5 : Open 3.27
E : Trac-Lok 3.27
2 : Open 3.55
K : Trac-Lok 3.55
*Edit And the info for looking at the tag on the axle:
-CharlesLast edited by Birdofprey; 04-09-2018, 12:20 PM.
The sticky for the axle codes is in the aero/whale section http://www.grandmarq.net/vb/showthre...258-Axle-Codes
Originally posted by turbo2256b View PostI believe all boxes most common were 3.08s, PI maybe 3.27, trailer towing 3.55
My ‘97, like most non-HPP/Police models just has a 2.73 open.
all of my panthers have come with 2.73 open so far... 88 MGM GS, 93 CV LX, 2000 CV base. The 88 and 93 were upgraded to 3.55L though.
