Door locks busted
    Ordered two bushings for the driver door but I only needed one. Now I have one for the other door if I ever want to replace that one
    1991 Mercury Grand Marquis LE SOLD
    1972 Ford F100 Custom - 5.9 - Stock
    2011 Ford Fusion SE - 2.5 - Stock
    2018 Toyota Highlander XLE
      Amazon FTW!
        Does take much wear to make a difference I guess
          Not so fast, roll the window down to test and there is bushing#2. Plus its the rectangle ones so I gotta order another one.
          At least my lock is done. Wiggled the old one out with no cuts.
            yeah i can't ever remember which bushing it takes. Its some Mustang part, but Mustang hardtop and Mustang convertible are different I think. I actually need to replace the ones on the Mark VII. The ears are broken off of one and I temporarily "fixed" it with zip ties like 9 years ago. The window rocks some as it runs up and down but not nearly so bad as it did when the bushing wasn't even in the hole.
              It was NOT the convertible bushing for the tops after all. They are rectangular but they are too small for the guide rods. That’s what I get for not actually measuring beforehand.
                So I guess the front passenger actuator decided to go out also
