Boo. Suppose it's not that hard of job with one of these there fox cars. Say we ever want to go back to the digi dash, is there a way to change the mileage?
EFI wows, about to scrap it!
never got outside after dinner.
Nichicon PF(M) series
new replacement PJ series
100uf 16v 493-5010-1-ND (digikey)
exterior part number F1LF-10D929-AA
interior board number: E9LF-14A608-AA
caps required:
(3) 100uf 6.3v
(3) 2.2uf 50v
(1) 330 uf 10v
Exterior part number: F0LF-10D929-AA
interior board number: E2SF-4A608-LA CDAD-1
100uf 6.3v Nichicon PF
330uf 10v Nichicon ??
100uf 6.3v Nicicon PF
2.2uf 10v Nichicon ??
2.2uf 35v Nichicon PF
is what I have in my notes. Apparently I never actually recorded the new part numbers but you should be able to work it out from there.86 Lincoln Town Car (Galactica).
Thanks gadget!
Although John Wilkes Booth got a hold of Ashley's Lincoln... I tried amateur diagnosis, it did not light off with starting fluid, found sickly yellow spark and 10psi or less of fuel pressure. Also, broken connector on aftermarket coil. I suspect dead fuel pump and coil but off to shop it went since I've got too much shit in the air to juggle at this moment.1985 LTD Crown Victoria - SOLD
