I went thru many months of nightmares with a similar problem you are having. My ECM was throwing a code 18 though. Turned out to be the distributor/ TFI module. I tried 2TFI modules from Advance auto on my original distributor before replacing with 3 Carquest reman dizzys and finally 1 MSD probillet and had nothing but problems before finally going to the junkyard to find an old Motorcraft dizzy, which fixed all my issues... go figure!
I replaced the TPS, MAP, plugs/wires/cap/rotor, timed it perfectly, battery, alternator, swapped the ECM 3 times, put a new 22Kohm resistor in the old harness, replaced the harness, replaced the ignition switch, the alternator 3G wiring I re-did, redid all my grounds and checked all my fuel injectors, changed out the ECM relay, new EGR, checked the fuel pressure and inertia switch.....all before finding out it was the MSD Probillet dizzy/TFI combo. Hope this helps if you start to go down this road.
