High idle and "Check engine " light
    I was driving my 89 Colony park today and I noticed the "Check engine " light flashed a few times while coasting to a light and while slowing down for traffic. When I pulled in my driveway the idle was way up, like 2000 RPMs. The light never came on again, but the idle would not come down. I shut the car off and waited 5 minutes before starting it again.
    It idled normal and no light. Any ideas? WagonMan
    89 Colony Park
    90 Colony Park
    70 HEMI Daytona Convertible
    Maybe a dirty IAC or throttle blade? Other than that maybe check the wiring to the IAC to be sure it's not worn in a spot and grounding out somewhere.
      Did you read the codes? I would suspect and EGR code but I'm not sure if they turn the light on. Not all codes cause the light to come on.
      | Junkyards
        not much sets the light, but a bum TPS will do it and that might mess with the idle. Code scan time
          Also, is the ECM's temperature sensor connected/good? I accidentally left mine disconnected and when I got to work the idle was up to 2k or so. Plugged it back in and all was fine. Opps.
            I changed the TPS and its fixed. Thanks for the help. WagonMan
            89 Colony Park
            90 Colony Park
              This guy is good haha
